Hi Val---firstly , yes If you want to ask a question, just post a new topic----look at all the sections, and decide which one would be best--say, for instance "Matt on TV" , then when you get into that page, before you go into all the little sections, at the top is a lttle button saying "New Topic". Just click on that , and you will get the "New Topic" board---at the top is a space for you to put the header for your new topic, then you fill in the rest , as usual. Or you could do it, straight from the bottom of this page, where you will se a "New topic" button. and do the same as above.
As for your photo, if you have it scanned ito your computer, all you need to do is send an email to
murph@lagos.me.uk---explain what you want., who you are etc.
At the bottom of your email should be something that says "Attach File"
Click on that, and you will probably get a browser window---you need to find the file where your scanned photo is--once you have found the file, click on it, and it will attach itself to your email--then send it.
I hope it works for you, as I am no expert myself. Good Luck.
Marian
