Page 1 of 1
Cannot find track names in iTunes
Posted: Sun Nov 10, 2013 10:11 am
by Wahzy
Hello.
I have just received this CD. First disc imported fine into iTunes. All track names are correct. However for the autiobiography discs there aren't any names. Is there any way this can be rectified?
Alex.
Re: Cannot find track names in iTunes
Posted: Sun Nov 10, 2013 11:42 am
by mariana44
You can put them in yourself manually---or there is a button , on one of the top menus, that says "Import track listings" or "get track listings"and it will connect with the database and put your track names in-not quite sure where it is, as Itunes keeps updating and things change.
Posted: Mon Nov 11, 2013 10:43 pm
by Rmoore
The tracks have no names. Originally EMI wanted me to put them as one long track on each disc. I was able to persuade them to allow me to put track markers onto the disc so that it would be easier for the listener to find a place on the disc.
Posted: Mon Nov 11, 2013 11:40 pm
by mariana44
ThanksRichard--I would not have liked to have them as one track--what if there was one specific track that you wanted to listen to a few times--or put your favourites onto Itunes.
Obviously , in this case the only answer is to put the track details in manually--I have done that often with Lps, that I copied onto a cd.
