18 Carat Gold Toothpick
Posted: Tue Mar 31, 2009 12:56 pm
After the success of the last sale it seems some of you are hungry for more. This time round you are bidding on a
18 carat gold retractable toothpick. Twist action with an engine turned pattern and hardened gold blade. Engine turning is the highly skilled process where lines are cut into the gold to create patterns on the surface.It measures approx. 7 centimeters when extended. Can be attached to a key-ring or chain. Matt wore it on a chain.
http://img25.imageshack.us/gal.php?g=dsc05897x.jpg
Opening bid must be higher than £20.00
If you wish to bid then place your offer here by pressing 'post reply'.
If a person has already left a bid then you will have to bid more for it to be accepted.
All items have a reserve. Once the reserve has been met a new message will be added and the word announcement will precede the item listing. If the reserve is not reached the item will be entered into a worldwide auction on Ebay in the near future.
Auction will end at midnight British time on Tuesday 7th April
Good luck.
Michele
Good luck.
Michele
